booo~ ing noise
I can't explain this noise. It happens when I turn the steering to complete left and reverse the car. It is really like a trumpet sound and I feel the vibration thru the stering into my bone.Who candiagnosis this problem? |
RE: booo~ ing noise
Try bouncing the suspension with your hands on both fenders. If you hear any wierd noises its probably the upper control arms. If you can't hear anything lift the front wheels off the ground and have someone turn the wheel lock to lock and watch the tie rod ends for play.
RE: booo~ ing noise
Okay, Thank you. I will.
RE: booo~ ing noise
how do you turn on wheel lock?
RE: booo~ ing noise
Have you put on larger tires? Might be the tires hitting the fender wells?
RE: booo~ ing noise
Tsi88Kid - not a "wheel lock". Turn the wheel all the way right to all the way left then back again- as far as it can go in each direction, aka "lock to lock". (If you were joking, I missed it.)
RE: booo~ ing noise
ORIGINAL: Tsi88kid how do you turn on wheel lock? Wait wait You use a key to unlock a wheel lock. I don't know if you need a key to lock a wheel lock! Don't confuse a wheel lock with hubcap locks or The Club. Sometimes the local police dept will put a wheel lock on your car. In that case the best waytounlock a wheel lock is apply money. Some people attempt to cut the wheel lock with a torch but that is not recommended beacuse it can damage a tire. |
RE: booo~ ing noise
ORIGINAL: NH_USA Sometimes the local police dept will put a wheel lock on your car. In that case the best waytounlock a wheel lock is apply money. Some people attempt to cut the wheel lock with a torch but that is not recommended beacuse it can damage a tire. |
RE: booo~ ing noise
tires are regular one for 2.8 a6.
