Brake Disc code for 2001 A6 4.2
I went to order some front brake discs from Pelican Parts but there are 3 different sizes, 288mm, 312mm, and 321 mm. Is there a code for which brake disc size is on the car so I don't have to pull the wheel and measure them?
Thanks. Ed |
Check your maintenance book for the codes. Do a search for codes online or use the bentley to verify. If you can't find it in the maint. book then check the spare wheel well. That'll get you started.
