Sponsored by:
Sponsored by:
Brake pads lights
Old 08-14-2009, 12:03 PM
Sayara's Avatar
Default Brake pads lights
Private Message: BRAKE PADS LIGHTS
Recipients: Kevin
08-14-2009, 10:01 AM
Sayara
Junior Member Join Date: Jun 2009
Hi All:
thanks for your previous help...my brake pads lights come on and all are fine as checked by dealer here in Calgary Canada on my US model 2005 A6 32. .
Any ideas? I was told by US dealership that the sensor in the pad could be replaced; here they say the pads have to be changed.
thanks.
Old 08-14-2009, 12:21 PM
ImTheDevil's Avatar
I don't know of a way to change a pad sensor. My understanding is that the pad wires are embedded in the pad material and when they're sufficiently worn, they touch the rotor and create a short that trips the light. Just replace the pads - easy work and they're cheap enough.
Old 08-14-2009, 12:54 PM
histeel's Avatar
Default Brake pads
Most likely if your pads are not worn your sensor wire has been cut or you have a bad connection at the plug, you cannot fix the sensor you must replace the pads, If the wire is cut or broken you can splice it check the routing of the wire could have got pinched. clean the connection plug you could have corrosion.
jinsojoo
09-16-2021 04:49 PM
speedracr226
08-05-2009 05:07 PM
br.drums
09-11-2008 04:46 PM
madridlover
04-09-2007 06:52 PM
black b5
06-01-2005 09:36 PM
Quick Reply: Brake pads lights
