brakes help
Old Jan 27, 2012 | 11:41 PM
malhar's Avatar
Default brakes help
im looking to replace my rear rotors and pads. need some help. i replaced the rotors last time not much of a problem.
how do u replace the rotors? a local shop said it cant be done without "special tools from the dealer"
any links to DIY with pictures?
and i also need a good place to get replacement rotors, i already have autozone pads.
i believe there were different style made in 01 so heres my VIN:
2001 A6 QUATTRO 2.7T
WAUED64B81N164980
Old Jan 28, 2012 | 08:24 AM
RGT's Avatar
RGT
The only special tool you should need is the key for turning the piston in the caleper back in, I would think most parts stores carry it, and it was cheap, I don't remember having any trouble finding one when I did mine, my car is an '02
I got my rotors at FCP Groton online...they probably sell the tool also. you can use this code for 20%off: maxrossi20 it was given to me with my last purchase and they said I could pass it around....
Old Jan 28, 2012 | 09:58 AM
jseklund's Avatar
It is a standard brake caliper tool that you can rent from Autozone for about $30-40 and then return when you are done, getting your $30-40 back.
Just so you know- your car has 3 differnt rotors that were used. You should pull one of the rotors off your car and measure the hat heigh and diameter before you order - if you get the wrong ones, they won't fit on there.
Old Jan 30, 2012 | 07:28 PM
malhar's Avatar
Default need urgent help
i was trying to replace them today, got all the right parts.
got the brake caliper tool, problem is that the piston is pushed so far out that the took isnt fitting in inorder for me to push/twist it inn.
im stuck now because my old pads were soo worn that one of them fell out already (it wasnt there when i took the wheel off) the other side had decent amount left. dont know why only ONE SIDE of the ONE ROTOR went out
anyways; is there anyother way to push the caliper in? even a little so that the tool fits, i need about 2cm
Old Jan 30, 2012 | 07:57 PM
turbo kraut's Avatar
Tech Guru
Vice grips/turn/push. Prob have a froze caliper though
mharris23
Jun 19, 2009 08:59 AM
DomsA4
Apr 24, 2008 06:53 PM
milla290
Jul 19, 2007 01:31 AM
dtownhotcorner
Sep 22, 2006 11:49 PM
dscott
Jul 4, 2006 06:14 AM
