A/C and external temp sensor related?
Old Aug 7, 2009 | 09:38 AM
jeffwantsaaudi's Avatar
Default Is it possible to reset the outside temperature sensor?
After timing belt, thermostat and PS pump change, I also changed out the forward radiator cooling fan. When working on the fan, I might have unplugged, but then replugged, the outside temp sensor. When done, the external temp sensor showed about 60 to 70 degrees F low, e.g., actual 70F outside shows as 10F on the guages. At the same time, the A/C stopped working unless the outside temp guage showed about 38F or so. Won't come on when "Lo" is selected, either. They seem tied together, but could just be coincidence. The Bentley manual is no help on this.
Recap -
A/C works, but only when external temp sensor shows a temp of about 38F
External temp sensor works, but shows a temp that is about 65F less than actual
Sorry if this has been previously covered, but I couldn't find a reference to this problem.
Last edited by jeffwantsaaudi; Aug 7, 2009 at 07:01 PM. Reason: restate what i need help with
toboater
Oct 26, 2010 12:15 PM
kylebee
Nov 12, 2008 08:21 PM
geno
Jan 7, 2007 09:35 AM
bjorn
May 9, 2006 09:16 AM
Mikeoh
May 9, 2006 08:54 AM
