A/C Problems
Old Apr 12, 2008 | 11:54 AM
1moehit's Avatar
Default A/C Problems
Last year I bought '99 a6 Quattro and for some reason A/C would only blow hot air. The engine doesn’t heat up or anything, and the heating in the car works great. But, even if I don’t have the A/C on, I am still getting hot air no matter how low do I set the temperature. Sometimes the regular fan is a little cooler, but only when the outside temperature is low and A/C will still blow hot air. I tried recharging it, but it didn’t help at all. Any suggestions to what could be wrong...
Old Apr 12, 2008 | 03:18 PM
auditech79's Avatar
Default RE: A/C Problems
Im confused, you say the engine doesn't heat up, but you get hot air out of the vents? You can't have both of those, does your temp gauge from the engine reach the middle and stay there?
As for the A/C, Im gonna need the fault codes, to read the codes in the A/C system you need a VAG COM www.ross-tech.com which is a diagnostic software that enables you to use your lap top to pull fault codes and log data. Other than that you need a set of manifold gauges (which you can't get) to diagnose the system pressures.
Old Apr 22, 2008 | 08:46 PM
1moehit's Avatar
okay, i got the cable and the software, which codes do i read? i tried to look for a/c couldnt find one....
Smokin Tubes
Feb 5, 2012 10:11 AM
mykien23
Dec 2, 2011 08:55 AM
redrhino
Oct 26, 2011 03:49 PM
commedecargons
Nov 9, 2005 06:43 PM
SamJamaica
Jun 13, 2005 02:07 AM
