Camshaft position sensor and brake
Hi all, im new to this forum as i just bought 02 audi a6 3.0 quattro with 85K miles. The CEL just came on and it says camshaft position sensor bank 2 on normal obdII reader that my buddy has(i've bought ebay vagcom cable and download the VCDS+ordering bentley manual). Im just wondering which part should i buy? the impulse sender, position sender, engine camshaft position sensor, or will it be reference mark sensor? I have also bought the rear brake pad as the current one is about to be out. Is there any specialty tools needed or is it just like normal brake pad change? Another thing, when i brake, the front driver side seems to lock and unlock the brake when it's close to a full stop. No ABS light is on, but the axle boot is torn, which put lots of oil/gunk. At first i suspect this nasty thing makes the sensor dirty and read improperly, but after i clean it up, it still do this thing (gonna change the axle this friday too), any idea on what might cause this? appreciate all the help
If the code is camshaft position sensor then there is only one on bank two luckily thats the easy one to get to as its right on the front of the head facing the front of the car. It's the round cap with two 10mm bolts holding it on.
At 85k has your timing belt been done yet? if it hasnt I would waste no time in doing it I bought my car with 88k and my timing belt was about to fail it had cracks all the way across just a heads up. If your timing belt has been recently done and something wasnt lined up quite right it can kick a cel for cam position sensor also so knowing a little history on your car can help diagnose this issue.
As for the brakes my first guess since your not getting any abs lights would be that the grease from the axle has gotten on your brakes and is causing your grabbing issues. I would get everything cleaned up good and see if your problem goes away.
the thing is i dunno whether the tb has been changed or not, should i open all the way to the timing belt cover to look at it, or should i just go ahead and buy the tb kit from blauparts? isnt that if the tb has slipped or skipped a tooth, the idle gonna be rough?
It could be that the car had the timing belt replaced by someone who didn't know what he/she was doing. Cam shaft position sensor codes are usually (but not always) from a bad timing belt job.
Thanks for the input, as for know i havent driven the car for a week yet, while im waiting for my new sensor. Gonna change the sensor and see what happens with the CEL. Im gonna order the tb kit too next week. On the other hand, has anybody experienced the same brake problem like mine before?
Peterhopson84
08-20-2013 09:57 PM
jkjersey
B7 Models
06-17-2013 09:31 AM
