Can the grill be removed with the hood closed?
SO my hood wont open again, its the same problem I had last night, the pull tab is stuck up behind the grill. Except now its much higher and I cant pry it down with anything. Is there any way I can remove the front grill without damaging it?
Thanks in advance
Thanks in advance
Its a 2000, but I solved the problem already. My friend took a die grinder and basically made the existing notch in the grill taller, which freed the pull tab and hopefully eliminated any future possibilities of it catching up there again. Thansk for the input guys.
flynnr
07-05-2010 03:48 PM
