CEL Codes: P0411 P1141 P1129 P1127 P1139
Help Me i had a CEL and got it check and threw 5 codes P0411 P1141 P1129 P1127 P1139, I know this has to do with the air/vacuum system but a little more help would be useful I have a 1998 2.9L A6
RE: CEL Codes: P0411 P1141 P1129 P1127 P1139
Your screwed - Prepare to spend money!
OK OK one can say that for almost any Audi CEL P0411- is secondary Air Injection System (B2) - incorect flow P1127 is Long term fuel trim - System too rich Bank1 The others - P1141, P1129, and P1139 don't show on my lists or theBentley. If you give the numbers that show before the P number I might be able to give you a bit more help.. For instance P0411 can also be read as 16795. The P numbers are SAE and the others are VAG. What ever that means??? Since your probably seeing codes for both banks -- I'd clear them and see what returns before spending a bunch on money. |
1141=load calculation 1129=bank 2 fuel to rich 1139=same as 1129
Help!
I have the same codes! Did you find a solution? What is it? Let me know ASAP! Thanks in Advance...
I have a 98 A6 as well, I had a vacuum leak and it caused many codes. When you first open the hood in the rear center of the engine there are a bunch of small vacuum hoses. I needed to change many of these little hoses. I would clear your codes and replace any bad vacuum hoses. By doing this it should clear up some of the other codes.
