Change holder getting stuck, cup holder question...
My change holder is stuck, and it looks like a coin fell behind it. So, what I want to do is remove the useless thing, and put another cup holder up there.
1. What item number do I need to ask for? 2. Is this even possible? 3. How do I remove the change holder and add another cup holder? |
RE: Change holder getting stuck, cup holder question...
don't know if it's possible, but I saw the cup holders on ebay. I think for about $20. I was thinking about doing the same if it doesn't involve pulling apart the dash board.
Pull the trim piece above the cupholder/changeholder off. Remove the radio. The cup holder and change holder are held in by clips at the top. Press down on the two clips with a small screwdriver and pull the holder out. Once you get both of them out you can compare them to see if they will interchange. You can also try sliding your existing cupholder in the change holder slot. I think the two are interchangealbe.
