changing language display..
i own a 2004 a6 2.7 sline package, everytime i start the car up.. her display shows up in french..the manuals doesnt tel me how to change..can anyone help me at this please?
probably need change the ecm code to usa via vag-com
vag-com?im totally new to all this..can you please brief me ?
it is a communication cable that connects to your OBDII port and can read fault codes, log stuff, change module settings etc...
http://ross-tech.com/ |
thank you..
Don't worry, I think most people who move to a new country or just start speaking a different language go through this stage. When I started learning Russian, of course, I taught it with online Russian tutors, which helped me a lot, because I specifically chose a native speaker. But nevertheless, I tried to communicate with Russian guys more often, I found them on the Internet and started to chat so as to overcome the language barrier. You just need more practice.
Have you ever thought about improving your german? I think if you know the basics, it'll be pretty easy for you to improve your language skills, and I can even recommend you check out the best apps to learn german fast. Personally. I use them as well to learn this foreign language, and I can say that they work pretty well.
It's a very complicated question, but if you can't solve it, you can always use translation services. When I bought my Audi, I was in France, so it was logical that the display was in French and I couldn't change the language either, but I used an english to french translator to explain to the mechanic what was wrong and what I needed to fix, so I solved the problem very quickly. The language barrier is often a very big problem that needs to be addressed immediately.
| All times are GMT -4. The time now is 04:46 AM. |
