CHECK ENG CODE P1130?
Old Nov 13, 2007 | 11:50 AM
AUDIA642's Avatar
Default CHECK ENG CODE P1130?
2000 AUDI A6 4.2 WITH A CHECK ENGINE CODE OF P1130...SOMETHING TO DO WITH FUEL AIR SENSOR? ANY IDEAS AND HOW TO FIX THE PROPLEM.
THANKS,
PHIL
Old Nov 13, 2007 | 12:18 PM
formulagigi's Avatar
Default RE: CHECK ENG CODE P1130?
is it what it read?
P1130 - Long Term Fuel Trim mult.,Bank2 System too Lean
are yuo not gettig P1128 too for bank1 system too lean?
I know someone who had both codes, dealer replaces MAF and sensor.
Are you running K&N air filter?
Check Vaccum line
Old Nov 13, 2007 | 12:24 PM
AUDIA642's Avatar
NO just P1130 code. Don't have a K&M Air filter...recently replaced with Fram.
Thanks,
Phil
Old Nov 13, 2007 | 12:31 PM
Does it ride rough or normal.
if it is a torn vaccum line on the secondary air system, which isvery common on all VAG vehicles, it will be ok to drive it. It doesnt effect drivability. Just more of an emissions thing.
Old Nov 13, 2007 | 01:14 PM
crazyfst02s4's Avatar
Old Nov 13, 2007 | 01:37 PM
AUDIA642's Avatar
Yes, vehicle runs fine. No change in response since light went on.
Old Nov 13, 2007 | 02:13 PM
DMSD's Avatar
Could be a vacuum leak or an O2 on bank 2. The ECU is looking at the O2s and sees it has been supplying more fuel to that side for awhile. I would check for vacuum.
Old Nov 13, 2007 | 02:42 PM
AUDIA642's Avatar
Will do...thanks
Old Nov 8, 2012 | 06:38 PM
97A8's Avatar
What was the outcome? I'm seeing similar codes now...
Srgarrett21
Dec 16, 2011 12:57 PM
AudiLover75
Apr 10, 2011 05:25 PM
ChadAudiA6
Jan 16, 2010 08:44 PM
RoboRabbit
May 10, 2009 01:17 AM
MilitantGrunt
Nov 1, 2006 09:16 AM
