Check Engine Code P1392
Old Jun 22, 2009 | 01:37 PM
copper07's Avatar
This code keeps coming back, even after changing the sensor. Does any one have any other ideas that I can try?
Old Jun 22, 2009 | 02:19 PM
copper07's Avatar
What should I try next to get this code from coming back?
Old Jun 22, 2009 | 05:36 PM
chefro's Avatar
Bentley gives you directions as to what to try next:
Originally Posted by greenquattro
From Bentley:
If the DTC does return and no malfunction is detected in the wiring and the voltage supply was OK:
Replace the Engine Control Module (ECM) J220 . Refer to Engine Control Module (ECM) J220 , replacing .
Old Jun 23, 2009 | 11:04 AM
copper07's Avatar
I have checked around for a replacement ECM and have seen a wide range of prices for the part. what is a realistic price for the ECM? Also I have read that you can reset the ECM, is this true or not?
Old Jul 7, 2009 | 05:28 PM
copper07's Avatar
Does anyone know a good place to order a replacement ECM?
Old Jul 7, 2009 | 06:13 PM
Copperfish100's Avatar
Does anyone know if the a 95 a6 and an obd link?
Old Jul 7, 2009 | 06:15 PM
Default spelling and grammar not my best trait
The question should have read: Does anyone know if a 1995 A6 have the data link for an OBD? and if so where would it be found. Thank you.
Old Jul 7, 2009 | 08:06 PM
  #18
NH_USA's Avatar
95 VAGCom connector is in the center console... Just in front of the cup holder - under the little cover. It is not OBD -- Get VAGCom
  #19
chefro's Avatar
The OBD is located under the hood (driver side, behind the firewall) in the relay box. Keep in mind that's OBD I type - two ports, so you'll need an adapter connector to use with the interface cable.
Edit: As NH said though, it is possible yours may be in the center console. The manual shows both locations as possible placements. Mine is under the hood.
Old Jul 7, 2009 | 08:20 PM
  #20
NH_USA's Avatar
My 95 had it in the console just like my 97 --
