check engine codes ?
Old Nov 25, 2004 | 04:19 AM
com2255's Avatar
Default check engine codes ?
My check engine light was on and I had a shop run the error codes which are as follows P1136 bank one & p1138 bank 2 sys lean. Also have P0441 and P0455. Any suggestion as to where to start checking these issue?
Old Nov 25, 2004 | 04:35 AM
com2255's Avatar
Default RE: check engine codes ?
oops forgot to mention it's a 99 A6
Old Nov 25, 2004 | 10:07 PM
Ted's Avatar
Ted
look for a vaccum leak, that is what the problem normally is. By the way is it a 2.8 or 2.7T
Old Nov 26, 2004 | 11:26 AM
com2255's Avatar
Thanks Ted, I did check the vac lines the other day but did not see anything obvious. I will be looking againg today.
Old Nov 27, 2004 | 05:52 PM
Ted's Avatar
Ted
what kind of motor is it, i can tell the places they normaly wear out....
Old Nov 27, 2004 | 10:50 PM
com2255's Avatar
ted, its a 2.8 quattro any help would be appreciated.
Thanks
com2255
Old Nov 28, 2004 | 12:01 AM
Jestnomen's Avatar
6th Gear
You're may not be able to "tell" if they are wearing out. You're better off just replacing them. The dealer should sell vac hose by the foot. A better alternative is to go to a porche dealer and buy theirs (3mm If i remember right). They last longer than the Audi stuff.
Old Nov 28, 2004 | 12:50 AM
com2255's Avatar
Thanks I will consider doing that although the hoses look like new. I have also thought about the purge valve being stuck open which may cause the lean condition (P1136 & P1138) and also the P0441 (incorrect purge flow) as well as the P0455 (large leak detectede mmission control system).
I also failed to mention that after feuling the car is difficult to start. It will crank and sputter to life only after feathering the gas pedal and getting the rev's up for about 10 to 15 seconds. I'm thinking this could also be a lean condition created by a malfunctioning purge valve.
Any comments on these thoughts?
com2255
Old Nov 29, 2004 | 08:41 PM
Ted's Avatar
Ted
Well without the car in my sight, i would say that you are on the right track. Let me know how it turns out. Ted
Old Nov 30, 2004 | 03:45 AM
com2255's Avatar
I replace the purge value ($140.00 from a local Audi dealer) took about 15 minutes. Went back to the shop and cleared the codes. I have about 25 miles on since clearing the codes and so far so good. No CEL yet, may have solve the problem. I'll post again if it comes back.
Thanks for the help it greatly appreciated.
