Check engine light on!
Old Apr 16, 2006 | 05:18 AM
dmjay65's Avatar
Default Check engine light on!
I need help asap, check engine light came on for the third time in the three weeks. First it was the o2 sensors, then it was the mass air flow sensor and now it gives a code via VAG-COM, WARM UP CATALYST BANK 1: EFFICIENCY BELOW THRESOLD, does anybody have clue what this means and how to repair it. Thanxs
Old Apr 16, 2006 | 12:46 PM
dankhound's Avatar
Default RE: Check engine light on!
Probably means you have a bad catalytic converter.
Old Apr 18, 2006 | 12:38 AM
cary12's Avatar
Yep, probably the CATs. How many miles are on your car? If you don't have a warranty, they are covered federally until 77,000 miles. Take it to an independent shop and see what they say. If they say it's the CAT's, you can take it to Audi and have them fixed for free. If you have an extended warranty, you can have anything else fixed also. Mine just got out of the shop for the CAT's and mass air flow sensor and now it runs like a champ!
Good Luck!
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
