Check engine light please help
Old Aug 1, 2009 | 12:19 AM
kainkauz's Avatar
Default Check engine light please help
Hello i have a 2002 a6 2.7t. My check engine light has been going on and off over and over. The code is P0442 It says it could be a loose gas cap or defective gas cap or small emissions leak. I bought a brand new cap from audi and it still does the same thing. Does anyone know what it could be and how much it might cost to fix. Thank you
Old Aug 1, 2009 | 12:52 AM
Jeffla's Avatar
Causes
A code P0442 most likely means one or more of the following has happened:
* A loose or improperly affixed gas cap
* A non-conforming gas cap (i.e. not factory/original brand)
* A small leak/hole in a fuel vapor hose/tube
* Other small leak in EVAP system
* Faulty vent o-ring seal
Possible Solutions
With a P0442, the most common repair is to:
* Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.
* Otherwise, replace the gas cap, or
* Inspect the EVAP system for cuts/holes in tubes/hoses
Other than tracking down where the leak is, I don't see any other options.
Old Aug 1, 2009 | 01:03 AM
kainkauz's Avatar
I bought a gas cap from audi already but it keeps coming up. Ill try to check for the hoses tomorrow. Thanks for the help
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
