Check your oil pan
1 Attachment(s)
Here's what I discovered after removing the oil pan with 111,500 miles on an used engine...
Does your oil temp gauge work?
Mine stop working, just wondering if that might be why. I have 145,000 probably looks just like that lol... My next oil change Ill take the pan off clean it and the Oil Level/temp Sensor... before I buy one see if I can get it will work again.. |
Oil temp gauge works
I had to replace the original engine. Purchased the used engine online. Oil temp works. Water temp gauge is about half way. Use a can of oven cleaner on your oil pan (just like new) and used high temp RTV on the oil pan. I'm using Mobil synthetic 5W-30 (6.8 qts) and Mobil oil filter.
Originally Posted by 02AudiA63L_65
(Post 1413175)
Just the sludge and heavy carbon deposits. I'll probably give the engine a good flush or two on the next oil change...
