Clicking sound while accelerating 99 A6
Hey Everybody,
My 99 A6 Avant with 2.8L Auto trans, is making a clicking or rubbing kind of noise only when I accelerate. To make matter worse it only happens when the car has been driven for a while, the engine is nice and warm and the weather is around 70. It does not do it when the weather is around 60. The sound is only there when I accelerate, not when I idle or coast. Here is a youtube video of the sound. http://www.youtube.com/watch?v=nSBk_pJaXL8 Ideas so far, Differential fluid flush, CV joints (just had the front end checked by a mechanic and nothing came up):(:(:( |
Do you have any misfiring problems? If yes, then check your spark plugs.
If you haven't misfiring problems, then it could be one of the following two: - Dust shield rubbing against the rotor or - a Pulley (However, my ear isn't that mechanically inclined to detect a specific noise via a video clip) |
Originally Posted by chefro
(Post 1312739)
COuld be A/C related - pulley or secondary fan. You only here it at higher RPMs on a warm day...
If it is indeed temperature-related, then most likely Bob's got it.
In that video clip did you have the AC running? Or a better question: is the noise exhibited mostly when the AC is on? If it is, then the simplest way to determine if it is AC Compressor-related is to actually drive without the damn thing on to see if it goes away. ------ |
(Post 1312776)
In that video clip did you have the AC running? Or a better question: is the noise exhibited mostly when the AC is on? If it is, then the simplest way to determine if it is AC Compressor-related is to actually drive without the damn thing on to see if it goes away. ------ Also can we rule Differential, and CVs out? |
Originally Posted by jassilamba@gmail.com
(Post 1312893)
I will have to test it with the air off. I did turn the fan on. Any ideas where that secondary fan is located (i will google and check the A/C pulley). Did I mention that going through a car wash last night made the sound go away for 5 minutes.
Does it sound like it could be exhaust leak at all. Usually its the other way around, loud when cold and quiets when warm. Just a thought though.
