CODE P0421 and P0431
I have these two codes, P0421 and P0431, on a 2000 A6 Avant. Are the catalytic converters warranteed separately somehow for a longer period than the car? Or is there another repair that can be tried before replacing the converters?
RE: CODE P0421 and P0431
Clear the codes and see if they return.
They do return usually in a day or two. This most recent episode was this week. I had the codes reset on Thursday, they returned on Friday morning after driving only about 15 miles.
converter warinty is 8 years and 80,000 miles.
Try running the BG induction cleaner through. ( you need to find a shop that sells BG services) MY friend did and the codes never came back, it seems the cleaner cleaned out the cats also. |
Thank you. I will look for a shop that does that.
I am beyond the mileage limit for the cat converter warrantee: too bad. |
| All times are GMT -4. The time now is 08:14 AM. |
