cold air intakes
would it do any use on my car? and is there a difference between a $250 and one that is like $40?
RE: cold air intakes
I would go with a nice filter / cutting a hole in the bottom of your airbox! just about the same gains..... but would be intrested top hear about a cold air intake or the Carbonio
i will probably just do that. any filter suggestions?
alright wammy my k&n filter will be in on monday. how big of a hole should i cut?
cut a few small ones .. 1/4 inch
i will give that a try thanks joetm
reverend did you notice any difference... im thinking of doing the same thing " post some pics of the air box if you can thanks "
i got the k and n air filter for like $48 and already i notice a little difference in the sound and i get like an extra mpg so far it is worth it.
yeah the k and n filter helps a little ... but did you drill the holes in the air box
yea you will see a much bigger difference if u drill the holes
