Cooling problem
Old Mar 11, 2007 | 12:34 PM
madridlover's Avatar
Default Cooling problem
98 A6 Quattro 2.8L with about 85k miles. My AC works but the air coming out of the vents is not very cold. Does anyone know what that could be? Do I just need to have the AC serviced? Or is there some underlying problem that others have experienced?
thanks in advance.
Old Mar 12, 2007 | 05:03 PM
Default RE: Cooling problem
Can nobody help me out here? I'm sure someone has experienced this problem before.
Any help is much appreciated.
Old Mar 12, 2007 | 06:56 PM
mustang196718's Avatar
your AC might just need recharging, seeing as how it's almost 10 years old, you're probably due for one. also, what is the ambient temp outside when you're trying to use it? from what i understand, the computer uses the ambient temp outside to decide whether or not the AC compressor needs to even be on or not, so it might have just not been warm enough outside?
Old Mar 13, 2007 | 04:42 AM
auditech79's Avatar
Yeah, another way to check if the refrigerant is almost gone is your a/c control head won't come out of econ mode, this will also happen if you replace the a/c control head and don't perform the basic settings on the blend door preventing you from using you a/c.
Old Mar 13, 2007 | 10:50 AM
Thanks fellas, I'll have to ask the wife to check those things as the Quattro is her daily driver
Wsmith1118
Mar 25, 2015 11:44 PM
S4_charged
S4
Feb 11, 2015 11:16 AM
JustinFreese
Oct 8, 2013 12:15 AM
daveplayjeep
Feb 20, 2012 04:24 AM
EdEs
Sep 22, 2010 09:15 PM
