Cranking but not starting
my 2000 Audi A6 2.7T is having a wierd day. I changed the oil the same way I have done many of times before. i replaced my air filter too. My father cranked the car to clear out some old oil, I do not know if this has caused any problems but just mentioning it incase it had.
I checked mostly all harnesses including the problematic one on the air box. I noticed te on the coolant tank the harness on the bottom had no wires connected to it =( Is there a way this could be my problem? Is there a way to connect these just to check for the time being if it will start?
I haven't a clue about the wire but I changed my oil the other day and replaced the air filter. I started the car and about three miles later it began to buck and acted as if there was no power. The CEL came on. I limped home and just as I turned into the drive it started running OK. Vagcom said it was an O2 sensor/vacuum leak. I cleared the codes and it ran great today (100 miles) so I guess it didn't like all the clean air from the filter change... PS the old filter was very dirty..
