This damn thing has so many prblms! Now its the brake
Old Jul 13, 2011 | 12:52 PM
Venom21's Avatar
Default This damn thing has so many prblms! Now its the brake
This is the worst car i've ever had in my life and i've had 2 Dodge's and 2 Honda's which were a B and B+ in reliability..... This A6 gets a D-. And at only 52,000 miles.
Now its the damn BRAKE light screeching annoyingly in my ear everytime I take a right turn, and that damn P symbol lights everytime since it got stuck leaving me to tow it at 47,000 miles. POS.
Is the ear-piercing BRAKE light beep due to low fluid? If so, what kind of fluid can i dump in this thing? Its an 05 A6 3.2 quattro. Thanks
Old Jul 13, 2011 | 08:08 PM
sheldon's Avatar
I had the same issue on mine but my a6 2002 4.2 did that around 90k miles. Brake fluid level was dangerously low. Mine requires Dot4 brake fluid. Should resolve your issues if you don't have any broken lines / leaks
When you locate the reservoir the required dot number should be written all over the cap
Old Jul 13, 2011 | 08:31 PM
hxgaser's Avatar
Yes. FYI, if indeed the fluid is low, then it is probably pointing to warn brake pads. Unless you have a leak, the fluid does not go anywhere.
Any DOT 4 will work.
Mr. Phil
Apr 2, 2010 09:11 PM
daveedsfast
Nov 1, 2008 10:58 PM
silveraudib6
Jul 22, 2008 01:22 PM
mr.cAp
Feb 11, 2008 09:28 PM
jinyya05
Sep 12, 2006 03:03 AM
