Dashboard and the central console is dark
Hello guys....i have an audi a6 c7 2013 2.0L My dashboard and the central console stopped working in this morning....the engine is working perfectly but everything else is not....does anyone have any ideas what could cause this??? I checked all the fuses and everything is ok |
I had a total MMI failure (no display or stereo) on my 2009 A6 Avant- turned out it was a bad wiring harness. I'd guess you're not getting power to the dash and console for the same reason. I'd double check the fuses, but if not its likely to be a "trace the wires" mess. Good luck.
Dave |
What is even stranger I found some whater in the luggage compartment underneath the spare wheel where the battery is. |
