I have some fault codes and an engine light car stalled turned off
2 Attachment(s)
12410
air intake flow too low p307a short with ground intermittent. 00104 Map/maf throttle position correlation P0068 short with power intermittent 12555 Low pressure fuel regulation fuel pressure outside p310b short with power intermittent P0068 Manifold absolute pressure/mass air flow throttle position correlation These are the codes I have My car stalled in D when I was driving and turned off on me then the next day when I started it and and put it in R moving out the parking spot the car started to turn off but it didn't and shifting it to N it turned off. I'm thinking its carbon deposits and fuel filter I am going to change the fuel filter and then carbon clean the engine and throttle body. Would appreciate any advice. http://s30.postimg.org/mkssfem25/image.jpg advance auto parts tool http://s30.postimg.org/bjxnadtt9/image.jpg advance auto part scanning tool http://s30.postimg.org/ty86ed63x/image.jpg All the codes from snap on |
I'm going to change the fuel filter clean the throttle body and carbon clean the engine look at the coil packs and spark plugs. Any other suggestions are most appreciated.
After changing the fuel filter this weekend along with cleaning the throttle body. The engine light turned off on it's own. I did not have to do anything. I still cleared all the codes and re adapted the throttle body. After driving it for about 15 mins the engine light came back on. I was low on gas my please refuel light came on 15 miles later. I filled it up drove around this morning the engine light was gone. I still checked it with the code reader and it said the low pressure for fuel. I cleared that code. It has been 24 hours since the job. The car still started a bit rough and if the code shows back up again i will repost it. For now i am going to carbon cleaned it and seal the engines this weekend if i can get some time. No codes no engine light so far.
