Default I have some fault codes and an engine light car stalled turned off
12410
air intake flow too low p307a short with ground intermittent.
00104
Map/maf throttle position correlation P0068 short with power intermittent
12555
Low pressure fuel regulation fuel pressure outside p310b short with power intermittent
P0068
Manifold absolute pressure/mass air flow throttle position correlation
These are the codes I have My car stalled in D when I was driving and turned off on me then the next day when I started it and and put it in R moving out the parking spot the car started to turn off but it didn't and shifting it to N it turned off. I'm thinking its carbon deposits and fuel filter I am going to change the fuel filter and then carbon clean the engine and throttle body. Would appreciate any advice.
advance auto parts tool
advance auto part scanning tool
All the codes from snap on
00104
12555
P0068
After changing the fuel filter this weekend along with cleaning the throttle body. The engine light turned off on it's own. I did not have to do anything. I still cleared all the codes and re adapted the throttle body. After driving it for about 15 mins the engine light came back on. I was low on gas my please refuel light came on 15 miles later. I filled it up drove around this morning the engine light was gone. I still checked it with the code reader and it said the low pressure for fuel. I cleared that code. It has been 24 hours since the job. The car still started a bit rough and if the code shows back up again i will repost it. For now i am going to carbon cleaned it and seal the engines this weekend if i can get some time. No codes no engine light so far.
danny_sykes_18
08-20-2013 10:55 PM
jasmix
12-01-2007 03:17 PM
