door blades
door blades
http://www.vaglinks.com/Docs/Audi/C5...lation_DIY.pdf
This is a c5 shape S6 door blades being installed on a c5 shape A6.
I was wondering if I could do the same on a C6 shape A6
Oh...us parts guys refer to those as 'lower door mouldings'...but "door blades" it is!
I honestly don't see how they could be retrofitted without extensive amounts of filler and be made to look decent...the lower portions of the C6 doors have a curvy upwards sweep and the C5 door blades are almost completely strait. Have you seen this done before?
UberTeile
UberTeile
Here are the part#s for the C6 S6/S line "door blades":
4F0853959LGRU - left front
4F0853960LGRU - right front
4F0853969MGRU - left rear
4F0853970MGRU - right rear
Good luck & hope this helps!
UberTeile
Yup...the door shells are the same between the C6 standard and "S" models, so the lower mouldings should bolt right up.
UberTeile
UberTeile
