Door Panel Removal Help...
Old Aug 25, 2011 | 12:51 AM
tuned2.7A6's Avatar
Question Door Panel Removal Help...
Forum -
Does anyone have/know where to find - an instruction list to "how to remove" both the dr and ps front door pannels? I have searched everywhere and either I'm blind or simply can't find it. I am going to change out my stock speakers with new ones and I cannot figure out to do it. I don't want to start bashing on things to get it off. I know it is more simple than it looks. I would appreciate any and all help guys.
Thanks.
Cheers,
Old Aug 25, 2011 | 01:08 AM
02A6Beau's Avatar
the guy that made this posted it elsewhere on the forum but anyway
Audi A6 Power Window Repair - YouTube
Old Aug 25, 2011 | 06:56 AM
jmarshall098's Avatar
Default how to replace power window motor for audi a6
Unscrew the screw from the door panel with the help of screw driver.
Release door lock cable and door handle cable from the door panel.
Remove the window switch by removing screws.
Check for a wire connected to the door panel light and if there is one then disconnects it.
Remove the electric connector from the switch and take it out from the door
Don’t stretches the door panel’s wind and sound protection cover (the plastic liner).
Tape up window glass to prevent it from falling down.
Lift the door up and remove the electrical switch connector from the window
Remove the stereo connector from the window door
There is no need to remove the locking mechanism of door window from the body of the vehicle because of alignment.
Remove the screw which holds the motor in its position with the help of screw driver
Now take out the window motor from the door
Take your time removing this assembly, as it is very tricky to pull out the Window Regulator from the door.
The next step is to remove three bolts holding the window motor to the regulator.
Note the position of the motor on the regulator.
If it was riveted in, you will need to remove the rivets.
Attach the replacement motor to the window regulator.
You can use nuts and bolts for this.
Put the window regulator in its place in the door, and reattach all bolts securely.
Now release the window glass very slowly, making sure all parts are reattached and seat properly.
Connect plug and window motor switch to check out whether window motor and regulator are functioning properly.
Now reattach door panel step by step in reverse direction, making sure all parts fit properly.
Keep in mind to reconnect and check out proper working of door lock cable and door handle cable.
You can buy low price window motor from here : audi a6 window motor
Tools required for window motor replacements are Regular screw driver large, Regular screw driver small, Door panel clip tool, 10 mm wrench, Socket and ratchet, Philips screwdriver, Extension with 8 mm socket
stenicilyg
Jan 6, 2010 08:04 PM
kjones6039
Aug 25, 2008 01:04 AM
auS4di
Jun 25, 2006 01:51 PM
auS4di
Jun 22, 2006 09:16 PM
sharkbait
Sep 7, 2004 12:17 PM
