:: ECS Tuning :: C5 A6 2.8 PCV Service Kits
Tired of garage floor stains and adding oil at every fill up? Chronic engine oil leaks may be a sign that your car has a more serious problem with its crankcase ventilation system.
Positive Crankcase Ventilation systems send cylinder blow-by gases back to the intake for burning. When they don't, crankcase pressure builds, pushing engine oil past seals and gaskets.
Bottom line? ECS has PCV Service Kits that cure the cause and fix the damage. Available in three stages, pick the one that matches your car's symptoms, and start keeping your oil inside the engine, where it belongs.
Stage 1 Kit Includes:
- Updated suction pump
- Updated check valve
- PCV breather hose
- Crankcase breather hose
- Replacement clamps
Stage 2 Kit Includes:
- PCV breather hose
- Valve cover gaskets
Stage 3 Kit Includes:
- PCV breather hose
- Cam chain tensioner gasket set
- Camshaft seals
- Cylinder head plugs
- Silicone sealant
Is this drip really necessary?
Click HERE to order or for more information
Fits:
Audi C5 A6 2.8L (1998-2001)
Let me know if you have any questions.
Jason
ECS Tuning
07-25-2013 04:04 PM
