:: ECS Tuning :: C5 A6 2.8L PCV Service Kits
http://www.ecstuning.com/sales/ecs600header.jpg
Have engine oil drips and dribbles from your 2.8L turned into gushers? If so, then new seals and gaskets alone may not slow the flow. Failed PCV is a common cause of multiple engine oil leaks. Clogged PCV lets blowby gas pressurize the crankcase and engine covers, pushing oil past gaskets and seals--all over. PCV can cause other problems: premature crankcase oil contamination; reduced engine performance; poor idle; a failed emissions test; and catalytic converter contamination. Fix the problem with three Emissions Service Stages that cure the cause, and stop the symptoms. Cure The Cause Click HERE to order or for more information http://www.ecstuning.com/marketing/A...rvice_Kits.jpg Fits: Audi C5 A6 2.8L (1998-2001) Let me know if you have any questions. Jason |
