:: ECS Tuning :: C5 A6 Quattro V6 2.8L Emissions Service Kits!!
Old Jul 29, 2013 | 04:49 PM
ECS Tuning's Avatar
Sponsor
Default :: ECS Tuning :: C5 A6 Quattro V6 2.8L Emissions Service Kits!!
Have engine oil drips and dribbles from your 2.8L turned into gushers? If so, then new seals and gaskets alone may not slow the flow.
Failed PCV is a common cause of multiple engine oil leaks. Clogged PCV lets blowby gas pressurize the crankcase and engine covers, pushing oil past gaskets and seals--all over. PCV can cause other problems: premature crankcase oil contamination; reduced engine performance; poor idle; a failed emissions test; and catalytic converter contamination.
Fix the problem with three Emissions Service Stages that cure the cause--and stop the symptoms.
Get the Sure Cure
Stage 2 kit includes:
  • Updated suction pump
  • Updated check valve
  • PCV breather hose
  • Crankcase breather hose
  • Valve cover gaskets
  • Cam chain tensioner gasket set
  • Camshaft seals
  • Cylinder head plugs
  • Silicone sealant
  • Replacement clamps
Click HERE to order or for more information
Fits:
Audi C5 A6 Quattro V6 2.8L (1998 - 2004)
Let me know if you have any questions.
Jason
ECS Tuning
Jun 11, 2015 04:10 PM
ECS Tuning
Sep 22, 2014 03:33 PM
ECS Tuning
Jul 29, 2013 04:51 PM
ECS Tuning
B7 Models
Jun 27, 2013 04:21 PM
ECS Tuning
Jun 27, 2013 04:18 PM
