ELectric fan not kicking in.
I think on my 2.8, the relay is right above the fan, under the "radiator cross member" (made that phrase up, just seems like that's what it would be called. I would imaging the 4.2's in the same place.
EDIT: Just checked the Bentley.
The Bentley does not include the 4.2 in its diagrams. I will paste all that I can find for the 4.2 and a little 2.8 as they cover that engine in more detail. Maybe it will guide you on where things might be for the 4.2
http://picasaweb.google.com/jeffmlaf...eat=directlink
That helps quite a bit thank you. Wish I could get my hands on a 4.2 relay panel diagram. Mine is not even close to the same as yours Strange that they wouldn't have one in there. I almost bought the manual just for that reason (to locate my headlight leveling relay) i would have been furious when I got it and found nothing....
They do include a few things for the 4.2's cooling system. You already have those pics.
http://picasaweb.google.com/lh/photo...eat=directlink
EDIT: Loaded up Elsewin, looks like most if not all the relays are behind the glove box. I find Elsewin extremely difficult to use. Auditech79 probably can tell you exactly where the relays are.
A6 4.2 Radiator Fan not turning on
I have a 2002 A6 4.2 and the radiator fans do not turn on.
I can't find the relays and the Audi parts counter says that is the most popular spare part in the power supply chain that fails!
Any help locating the relays would be appreciated.
Thanks, Paul
Thanks, Paul
It actually has 4 fans one mechanical two electrical for the coolant and one electrical for the oil and none of mine have been coming on any ideas? It's been a big problem for me for about 1 month now and i would really like to get this problem solved....
