Engine Fault Codes Please Help
I pulled the following fault codes And suggestions? P1423, P1411, P1476, PP1138, P1136, P1129, P1127. What does it mean?
RE: Engine Fault Codes Please Help
it is a leak detection pump failure or a blocked line any suggestions?
how does the car behave? and what pump are we refering to? i will be glad to make any suggestion and recomendation if i can
for the P1476 It's a leak detection Pump Failure located in the Drivers side rear wheel well. P1127 and P1129 are bank 1and2 too rich.
Then P1136 and P1138 are bank 1and 2 are too lean any help? |
Vacuum leak somewhere?
I checked underneath the hood and took off nearly everything on the pass. side and the wheel skirt I did not notice a vaccum leak
I check for a vaccum leak under the hood and the pass side wheel well didnt see or hear any. Where do i start
