engine light is on,need help
RE: engine light is on,need help
Its possible the purge valve connector is improperly connected. The purge valve is a little cylindrical device with a wiring connector and two hoses sitting on top of the air filter housing. Seeing as how they're working in thei vicinity for the turbo replacement, its a good change that something is disconnected with regards to the purge valve. Or, it is broken.It the hoses aren't connected properfly
no its above the airfilter,juat remove the top cover and look around,i did just that and it really was a loose connector then i eraced the light and it never came back
ssingh
11-07-2012 11:30 AM
inkhaton
08-16-2012 03:37 PM
ssingh
05-20-2011 08:03 AM
jasmix
12-01-2007 03:17 PM
