Sponsored by:
Sponsored by:
Fan Not Coming ON 2006 Audi A6 4.2
Old 12-22-2009, 07:32 PM
Mark9316's Avatar
Default Fan Not Coming ON 2006 Audi A6 4.2
My Car is Overheating and I noticed that one of my Fans isnt coming on. I want to check the fuses but cant find them anywhere can someone please let me know where they are??
Old 12-27-2009, 09:28 PM
maxim_s45's Avatar
There are two fans - one is cooling related and one for AC - which one is not coming on?
Old 12-27-2009, 11:25 PM
Mark9316's Avatar
The one to the right if I am looking out my front window
Old 12-28-2009, 07:44 AM
maxim_s45's Avatar
This is AC - should switch on when you switch AC on.
1. Fan to the left - does it switches on?
2. At which temp?
3. At which speed (there should be too speeds - low at 80 and hi at 90 celcius).
4. When it switches on - does it cool down the car?
Old 12-28-2009, 06:26 PM
Mark9316's Avatar
The fan to the left does not switch on
Old 12-28-2009, 08:47 PM
maxim_s45's Avatar
I would do:
1. unplug temp sender from the bottom of radiator, shortcut 1-3 on the plug -> fan should start max speed, shortcut 1-2 -> fan should start lower speed. If the fan runs in both cases - then temp sensor failed
2. if both speeds fail then connect fan directly to battery +12 - will check the fan working. If not - replace the fan.
3. If fan is working - then check wires and relays. Let me know if this is the case...
Old 12-29-2009, 12:08 AM
Mark9316's Avatar
Thanks so much. Where are the fuses and relays??
Old 12-29-2009, 08:28 AM
maxim_s45's Avatar
In my 2004 model:
in a panel behind driver's storage compartment: relay #2 for 2nd speed of the fan, relay #3 is the main radiator fan relay, relay #4 is for radiator run-on. In the same panel - fuse #19 is for radiator fan, fuse #21 is for fan control unit, check fuse #22 as well.
I know that for allroad models - there are extra.
Old 12-29-2009, 10:02 AM
Mark9316's Avatar
When you say the drivers storage compartment can you be more specific. The only fuse box I see is the one that's located on the side of the dash when I open the drives door.
Old 12-29-2009, 12:42 PM
maxim_s45's Avatar
It is under the wheel - you have to remove a big panel on 5 bolts which is under the wheel and above your knees. I remember I had to unclip dash panel insert and trip on the driver's side to unscrew all 5 bolts.
Quick Reply: Fan Not Coming ON 2006 Audi A6 4.2
