fault code show check engine light on?
Old Jul 20, 2007 | 07:46 AM
thetryal's Avatar
Default fault code show check engine light on?
is there a specific fault code that would be present if the check engine is on? what if the CEL came on then went off? for the CEL to be on i understand that some sort of fault code would most likely be present, but i am asking for the code that specifically says the CEL was/is on? thanks
Old Jul 20, 2007 | 11:49 AM
Jeffla's Avatar
Default RE: fault code show check engine light on?
It could be 1 of 500 different things. Go to Autozone, have them read the code and then post the results.
Old Jul 20, 2007 | 11:54 AM
techbod's Avatar
if the CEL goes off then it was an intermittent problem and a soft code will be stored and if it happens 3 times the CEL will stay on but until then I woudnt worry over it ( you could check the code for peace of mind at autozone ) then they could clear it
insanoman85
Apr 12, 2010 10:58 PM
jeffwantsaaudi
Dec 20, 2007 06:49 PM
shkenned
Jul 22, 2007 06:28 PM
akindy
Jul 2, 2006 04:01 AM
a4ddt
Sep 27, 2005 02:01 AM
