Faultcodes from VAG-COM
Old Sep 14, 2007 | 05:22 AM
Maverick84's Avatar
Default Faultcodes from VAG-COM
Hi!
Got these codes from the VAG-COM auto-scan sequence.
Also, I couldn't get into two modules in the VAG-COM, 09 -Centr. Elec. and 46 - Centr. Conv.
Is there aCAN bus i my car? How do I find it out?
my car is a '99 Audi A6 EU model, 2.5 TDi Q Avant.
Address 01: Engine Labels: 059-907-401-AKE.LBL
1 Fault Found:
00741 - Brake Pedal Monitoring
27-00 - Implausible Signal
Readiness: N/A
Address 02: Auto Trans Labels: 01V-927-156.LBL
1 Fault Found:
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.LBL
Part No: 4B0 820 043 S
Component: A6-Klimavollautomat D63
Coding: 00063
Shop #: WSC 02325
3 Faults Found:
01810 - Actuating Motor for Temperature Flap; Right (V159)
41-10 - Blocked or No Voltage - Intermittent
01842 - Potentiometer/Actuator for Temperature Flap; Right (G221)
30-10 - Open or Short to Plus - Intermittent
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
Address 34: Level Control Labels:
Note: Excessive Comm Errors
Address 35: Centr. Locks Labels: 4B0-962-258.LBL
Part No: 4B0 962 258 D
Component: Zentralverriegelung D32
Coding: 04673
Shop #: WSC 00000
1 Fault Found:
01570 - Turn-Off Delay; Terminal 15
29-00 - Short to Ground
So, where to start and where to look?
What wiring diagram do i need to get to find the short in terminal 15?
Fixed my Disabled Airbag, passenger side with the adaptation in airbag, and the coding for my RNS-C was all wrong, the original code was 00017, changed it to 00207, and got sound in my front speakers again (was set to "Bose sound", with 4 active speakers.) Now it says no Bose, with 2 passive spk. in front, and 2 active in the back.
Thanks
J.
