Few questions
Few questions
2005 A6 4.2
1) Is there a way to reset your nav? Took a long trip recently and the thing hasn't recovered. Shows me 100's of miles away from where I actually am rendering it useless.
2) My automatic steering wheel adjustment is only working in the forward/back direction. Won't go up and down. Is that as simple as just the button being bad?
3) My AC randomly stops working. I have discovered if I rev the engine hard it comes back on and stays on for days. Anyone experience this? Relay, controller or something?
Thanks for any help folks.
1) Cancel destination (hit the bottom right MMI button and the cancel destination selection should pop up)
2) My guess is the motor has gone bad. They replaced my steering column because of a similar problem a few years back.
3) I set up a TSB library with the help of a fellow forum member. Take a look at the HVAC section and see if one of the TSBs describes your situation.
http://uberlame.com/a6_tsb/
Kevin, good to see you still on here.
It's not that. Funny because it will do everything but track. I can put in a address, map it...hit START and it will calculate. Just comes up like 900 miles to work. Too bad I've really grown attached to it.
GULP
I'll go have a look.
GULP
