First Audi
I Own A 2003 3.0 And It Has 73K On It, I Had Oil changed Yesterday And Now The Minimum Oil Light Is ON. do The 2003 Have Alot Of Promblems Like This? Such As Electrical Issues
Did you check the oil level to make sure it was topped off after the fluid change?
Originally Posted by TwinTurboC5
(Post 1425518)
If the oil level is correct and you're still getting the low fluid indicator I would suspect that the oil level sensor/sender is faulty. Check first to ensure that it hasn't come unplugged. If its plugged in, I would simply replace it with a new one. The sensor/sender is located on the bottom of the oil pan.
You may have sludge.
