First Audi
Old Feb 21, 2013 | 10:15 PM
RyanR7911's Avatar
Default First Audi
I Own A 2003 3.0 And It Has 73K On It, I Had Oil changed Yesterday And Now The Minimum Oil Light Is ON. do The 2003 Have Alot Of Promblems Like This? Such As Electrical Issues
Old Feb 21, 2013 | 10:58 PM
TwinTurboC5's Avatar
Did you check the oil level to make sure it was topped off after the fluid change?
Old Feb 21, 2013 | 11:02 PM
RyanR7911's Avatar
Yes Its Fine Sorry Forgot To Mention That
Old Feb 24, 2013 | 07:28 AM
If the oil level is correct and you're still getting the low fluid indicator I would suspect that the oil level sensor/sender is faulty. Check first to ensure that it hasn't come unplugged. If its plugged in, I would simply replace it with a new one. The sensor/sender is located on the bottom of the oil pan.
Old Feb 25, 2013 | 12:10 PM
hxgaser's Avatar
You may have sludge.
