flashing check engine light
got in my car this morning and my check engine light started flashing and engine started running very rough after driving a couple of blocks. also have a sulpher smell. i know that i have a bad o2 sensor. does that have anything to do with it? should i drive the car to get the codes read or do i need to have it towed? any help or suggestions would be great. thanks!
RE: flashing check engine light
buy a $40 code reader and check yuor code unless someone near you has one or a VAGcom.
The code reader will prove itself vry useful! Post the code when you get it. Typically you shouldn't drive your car with a FLASHING CEL. Although whenI had a bad Coilpack, the light flashed temporarily and then stayed on.. car could be driven. Jst be careful until you know the code and problem |
the guy at autozone told me that i have a misfire on cylinder 5 and also P0050 HO2S Bank 2 Sen 1. i have to admit that i've known about the O2 sensor for awhile. do i need to replace the sensor in order to fix the misfire? any help would be appreciated. thanks! PS-my car is an 02 3.0L A6 avant
sounds like a bad coil on cylinder #5 and you need an o2 sensor.I wouldnt drive the car with the check engine light flashing....the check engine light flashing means that the car is in a catalyst damaging state meaning that you can burn up your catalytic converter if you continue to drive the car as is. I would at least get the misfire fixed ASAP.
I agree with 99A6Q get it taken care of as soon as possible. Especially the cyl 5 misfire, it is currently not firing and is letting raw fuel go out through the catalysts andbasically starting to fry them.
Misfiring are often due to a bad coil pack on our cars, which is typical and they will all go eventually. If you have a warranty, they are covered. if it is coil pack, no biggy driving to the shop... but since yuo don't know, just get it towed
thanks. i have a coil ordered and will put in in tomorrow. hopefully that's all it is.
P0050 = heated O2 sensor 1, bank 2 heater control circuit malfunction--- change the O2 sensor or check the wiring
thanks for the advice everyone. replaced igniter coil in cylinder 5 and no more misfire. what would i do without audi forum!?
