Flickering Headlight
Hi all again,</P> Names Kevin. Just aquired a 1 yr old A6 (2002 model). I notice sometimes that when I switch my headlight on, my left headlight flickers then no light, but when I switch it off and on again, It's ok. Could it be the bulb?</P> Thank you.</P> </P> </P> |
Xenons or Halogen???</P> Either case, I would check the bulb wiring / relays. If it is Xenons, check for water or moisture in or around the ballasts. Also, look for the connections on the bulb... Perhaps, the bulb might be bad..?</P> |
