Headlight bulb Replacement Fuses
Okay, I have the Xenon lights on my 2000 2.7t. I Replaced the headlight bulb after it went out. Well after I got it started again the bulb never came back on. My guess is I have a blown fuse but I have checked all over the car and I can't find the fuses. Can someone please let me know where these are so I can get my headlight working again.
Jason
Jason
RE: Headlight bulb Replacement Fuses
Behind the side panel on the side of the dash. Open the door and pry the panel off. If the bulb never came back on after replacing it, you probably have a bad ignitor. The ignitors fail far more often than bulbs. You may want to try swapping ignitors from side to side.
