headlight question
Old Jan 20, 2009 | 12:23 AM
helitech's Avatar
Default headlight question
my 2003 3.0 quattro didn't come equipped with HID's... i was wondering if i bought headlights that came with HID's with the ballasts and bulbs working, would it be plug and play for my model??? just thought i'd ask before buying an HID kit because my headlights are fading so i figured buying OEM HID equipped lights would be better... thanks guys!
Old Jan 20, 2009 | 03:55 AM
chefro's Avatar
Before spending a bunch of Benjamins, take a look at this article.
If you decide to do so, then you can purchase the Silvania Silverstar... $ 19.99/bulb at AutoZone, MadeInChinaMart, etc.
They have as much brightness and "sweeping angle" as the expensive HID's.
And get this: they are "plug and play", you don't need to perform any modification, and risk screwing up something.
I have them in both my cars, and I vouch that are as mean as the HID's.
But, hey, go with the fashion trend (a.k.a. HID) if you want to.
good luck to ya.
Old Jan 20, 2009 | 05:10 AM
helitech's Avatar
i had the sylvania silverstars in my lncer evolution and i wasn't impressed at all... it was dfinately an improvement though... but when i lined it up next to my buddies evo who had an hid kit, the difference was night and day... theres nothing faddish or fashion trendy about it.. you're definately getting your moneys worth with the hid kit... and i've had them on every car i've owned (and my motorcycle)... thanks for the lens clean up write up though!
Old Jan 20, 2009 | 12:41 PM
chefro's Avatar
If the difference is for you as "night and day", and you cannot see better with the Silverstars than with regular halogens, then you should definitely get HID.
Probably the car will finally look as good in a line up as your buddy's car.
good luck
Old Jan 20, 2009 | 01:35 PM
oc_audica's Avatar
silverstars don't do much if you have projectors.
OEM HID FTW... new sets go for about $800... used for $400-500
DO NOT get the cheap chinese ebay ones... only buy HELLA headlights if you want the entire assembly.
Old Jan 20, 2009 | 02:32 PM
the G man's Avatar
You cannot buy a oem HID system with modifiction. What you need is a aftermarket HID kit that will fit onto your existing sockets.
Old Jan 20, 2009 | 03:56 PM
oc_audica's Avatar
If you buy oem hella Xenon complete headlights, then it is just plug and play.
Old Jan 20, 2009 | 04:51 PM
helitech's Avatar
thanks OC thats all i needed to know!
Old Jan 20, 2009 | 04:54 PM
helitech's Avatar
Wink
good luck
look i understand you like silverstars, but the fact of the matter is they do not have as much light output as HID kits or OEM HID fitted housings... my cars ALWAYS looked good in the line up but thanks for the attempt at a low blow cheapshot comment... i was only referring to the light comparison... a lancer evolution which was daily driven putting down 403 horses to the floor on pump gas cant possibly look bad
Old Jan 20, 2009 | 05:25 PM
Jeffla's Avatar
oc_audica:
It is not just plug and play if you buy oem hid fixtures. His car will not have the headlight level sensors in the control arms. If you want the auto level to work you will have a small project on your hands.
