Headlight replacement 2000 a6
Hello I was looking to replace my headlights on my 2000 avant with factory HIDs... All lights I have found say they aren't compatible, any links or tips would be appreciated
Any pre facelift factory a6 hid headlight will work. Literally plug and play. But it is hard to find them in good shape, the leveler mounting tab have been broken in the ones I've found.
I was looking to go aftermarket for a different look would I have to rewire everything and get away from hids?
Aftermarket is fine, but you won't be able to use the stock wiring with out running a relay for the HID ballasts. The stock ones are plug and play
Yeah it came stock with hids but I wanted to convert it back sorry
you'll have to run a hid harnesss for the other set, then itll work
