help
so i go to the park with the kid and i park on a pretty steep grass hill thinking no big deal its an audi ill be fine. So about half hour goes by and i get back in my car and start her up and both my abs light and my esc light is on so i back down the hill turn my car off and turn it back on and it went away. this is the second time this happened didnt pay attention to i tthe first time just did the same thing turned it off then on..... ne suggestions
Here is what you should have said
"So I go to the park with the kid today and park on a steep grass hill. Of course I called for a flatbed to be on standby just in case. About 1/2 an hour goes by and I see the car has not gone up in flames and nothing looks broken (that's odd I think). It starts (no really it starts) and see that only the abs/esp lights are on. What a great day it has been."
You probably need a new abs module.
Jeff
Check for worn brake pads. As they wear, they allow more fluid into the caliper, so less is in the master cylinder reservoir, so when you park on a hill you get the warning light. Of course, don't change the pads until you need to, but, until you do, don't worry about the light.
Bob
Bob
