Help? A6 MISFIRING CEL
Old Jul 7, 2008 | 05:09 PM
kuruca's Avatar
Default Help? A6 MISFIRING CEL
Hello forum members
I recently got 98 a6 2.8Q
I'm having issues with CEL
Codes are cylinder 4,5,6 misfiring.
I put new coil, plugs andplug wires
still same Cels coming on.
Can you guys help
thanks
Old Jul 7, 2008 | 11:31 PM
formulagigi's Avatar
Default RE: Help? A6 MISFIRING CEL
hmm!!? Coil amplifiers maybe?
Old Jul 7, 2008 | 11:41 PM
kuruca's Avatar
what is the coil amplifiers??
here is the codes
P0300 random multiple cylinder misfire
P0304 cylinder 4 misfire
P0306 cylinder 6 misfire
p0305 cylinder 5 misfire
any suggestions??
thanks
Old Jul 8, 2008 | 01:20 AM
kuruca's Avatar
Does vaccum leak throws misfire codes??
Old Jul 8, 2008 | 06:03 PM
auditech79's Avatar
The coil amplifire is built into the coil, try swapping the coil to the other bank and see if the same codes come up. If it doesn't, you might have a wiring issue to the coil and need a professional to check the wiring/ECM.
Old Jul 11, 2008 | 01:54 AM
kuruca's Avatar
I changed all the vacuum hoses today
And swapped the injectors
but the misfiring is in same cylinders
WHAT SHOUL I DO NEXT
THANKS
Old Jul 11, 2008 | 07:54 AM
massboykie's Avatar
Member
Hey kuruca
Have you tried to swap the ignition modules? These are located on the air-box on my 2.7, not exactly sure if they are in the same place on the 2.8. There should be two and if you swap the wiring around the codes should go to the other bank. 123
Pics...
http://www.vaglinks.com/Pics/Audi_2...._Modules_1.jpg
http://www.vaglinks.com/Pics/Audi_2.7T_Ignition_Modules_2.jpg
Cheers
Massboykie
Old Jul 12, 2008 | 01:37 PM
kuruca's Avatar
thanks again massboykie
I did what you said and still same codes?
I'm going to do compressiontest tonight
what else do you guys prefer to do
thanks
cncbamf
May 9, 2017 05:39 PM
googlegot
Jun 10, 2012 06:25 PM
tketke
Nov 4, 2008 12:01 PM
limptimtim
Mar 16, 2007 11:21 PM
nitro_rider2001
Feb 27, 2007 07:39 PM
