Sponsored by:
Sponsored by:
whistling noise...
Old 12-19-2007, 08:34 PM
jkity's Avatar
Default whistling noise...
Tonight when i got out of work and started my car it wouldn't turn over the first time, it whistled really long (WEEEeeeeeeeeeeeeee). Is it a noise i should be concerned with? What happens when your timing belt goes?
Old 12-19-2007, 09:08 PM
mustang196718's Avatar
Default RE: whistling noise...
when your timing belt goes, the cams are no longer held in time with the crankshaft, allowing them to move to wherever they please. in a nutshell, the car won't run any more, so as long as your car still runs, you haven't broken the timing belt. as for the whining, i'm not entirely sure what that could be other than the fuel pump priming or possibly the secondary air pump for the catalytic converters.
Old 12-19-2007, 10:19 PM
frankinstyn's Avatar
Sounds like a vacuum leak. Pop the hood and check all the lines. Pretty easy to find.
Old 12-19-2007, 11:10 PM
Coors's Avatar
It's not your t-belt. Probably, the bendix in the starter. I have the same noise every once in awhile. Mostly when its cold. Granite my car is in a heated garage and I don't drive it everyday. But, when I do drive it and it is left outside in the cold as soon as it turns over I get the "(WEEEeeeeeeeeeeeeee)" sound for a second or two. That's the bendix in the starter, not disengaging. Have a qualified tech check it first, you probably have to replace the starter. Hope this helps.
Old 12-20-2007, 12:18 AM
germantech's Avatar
SoCal Crew Member
coors hit it right on the head, i would have your starter checked, easy fix....
good call coors
Old 12-20-2007, 10:23 PM
jkity's Avatar
Thanks Coors i'll do that first. Your explanation sounds just like what i experience. Thanks again, Tamara
JeboMan
02-24-2013 06:07 PM
vinnybin
09-08-2010 06:47 PM
tculber
01-11-2009 10:00 AM
BearTrap
11-27-2006 05:04 PM
barryoy32
02-24-2006 03:33 PM
Quick Reply: whistling noise...
