HELP! Lots of Beeps and Blinking Lights!
Old Feb 25, 2011 | 05:38 PM
reaper's Avatar
Default HELP! Lots of Beeps and Blinking Lights!
So I was having issues with my battery constantly dying and couldn't figure out what was up. After bringing it in to my work (auto shop) and looking through everything, it turns out that the amp turn on wire for my subwoofers which I had hooked up through the fuse panel was actually mis-wired. The amp had been powered on 24/7 and was killing the battery very slowly. While I rewired it to the fuel pump fuse and it is working properly now, I have a multitude of other problems. After starting the car for the first time following this I was greeted by 3 loud beeps and my ABS , Traction, and BRAKE lights were all illuminated. I have since tried to use my code reader to check it out, and All I get are the codes for my CEL (I have test pipes), and one saying that there is a malfunction of a camshaft position sensor. None of which I could imagine have anything to do with this. When I reset the light and erase the codes, it does not remove the ABS/Traction/BRAKE lights. What could be causing this? I checked my fuses and all appear to be in fine shape, but I am open to ideas. Any idea what this could be? I really hope I didn't fry my brake controller or something.
Old Feb 25, 2011 | 10:51 PM
D-rich's Avatar
if the abs light stays on and the brake light flashes i believe it means your abs controller has crapped out their are places that will rebuild them just do some searching but i think the best place for it is module masters
swimbikerunrun
Feb 20, 2016 08:43 AM
DefinedReflections
Jan 11, 2011 09:40 AM
kcosh
Mar 5, 2009 01:13 PM
littleflavio
Oct 27, 2008 09:52 AM
jjuzwik
Dec 18, 2007 11:01 PM
