Help- Transmision
Old Jul 21, 2011 | 04:51 PM
moises maldonado's Avatar
Default Help- Transmision
I apologize ahead of time for my lack of knowledge..
This all started when i added regular coolant instead of G12... major newbie mistake.. I wanted to die when i saw the ge-lo in my coolant tank. I flushed it 3 times since then to get the ge-lo out.. 2 days ago my car started to overheat and i realized it was low on coolant so i added more but it still heated up.. i finally found the culprit.. the ring around the coolant tank was oval instead of round and my cap was no good anymore.. because of the loss in pressure it would heat up and start to drop coolant from exit valve on the bottom of coolant tank. I bought a new coolant tank and a new cap which solved heating problem.. As i was testing it out i noticed my car would no longer go past 3rd gear and my tiptronic doesn't work anymore either. 1st gear goes all the way to 3,000rpms before it switches to 2nd, 2nd gear goes to 2,000rpms and 3rd gear kicks in instantly after. I called an audi repair shop and the mechanic i spoke with said he would need to rebuild transmission and it would be around $2,800. He said he just finished rebuilding one on another A6. I don't have that kind of money laying around so i came here hoping for your opinions and knowledge. I never had a problem with my transmission till 1 day ago when i switched coolant tank and cover..
History for the last 2 days..
1. car started to overheat to the point where the gauge showed hot 1 second and dropped to cold. Had just pulled into driveway as it happened.
2. Found coolant tank and cap was no good so i bought new ones and installed.. no problem there.
3. tried to drive car.. no more overheating but it wont go past 3rd gear.. i ca go up to 35 mph without forcing engine.
If there is anyone around my area i sure could use some help.
Old Nov 2, 2012 | 07:03 AM
old ben's Avatar
seems that the car is in limp mode as i noticed from reading these forums, The car overheated ...registering a fault code in the computer and to protect itself went into limp mode ,... now you fixed the problem but you still have to reset the computer (erase the fault code with vag com - etc) so the computer doesn't see the fault and stay in limp mode.
Hope this will help other readers on this forum since the post is so old.
i don't know all the models but with what i read is that after 40 starts it should clear. also some readers posted that you have to disconnect the battery for 10 min to reset the computer ( read up on this more before you do it please ) since some say you need codes for the radio and other things if you do disconnect the battery.
Bottom line you have to get the codes cleared witch ever way you decide to do it.
Old Nov 4, 2012 | 11:35 PM
Jackmup's Avatar
It could be the shift module or the magnets screwed up.
try clearing the codes.
If an Audi shop can diagnose a transmission problem over the phone how come they can fix the car on the lift? That's Just WiERd
Old Nov 5, 2012 | 07:21 PM
hxgaser's Avatar
Originally Posted by Jackmup
"If an Audi shop can diagnose a transmission problem over the phone how come they can fix the car on the lift? That's Just WiERd"
Amen! BTW, send me $1K over Western Union, I will fix the issue with my computer. More than 50% off!
Seriously, have someone really look at the car before assessing the issue. And ditto on everyone's comments especially that of Jackmup.
Cks69`
May 23, 2009 01:19 AM
Ron Holl
Dec 29, 2008 12:34 AM
Avant187
Sep 18, 2007 12:13 AM
xavx1
Feb 26, 2007 01:35 PM
kakarot
Sep 22, 2005 09:06 PM
